Post by ultramanmike on Sept 7, 2022 20:48:12 GMT -5
Hello everyone! I finally found a prebug and wanted to share my build list . I'd love to hear everyone's thoughts on my parts list. YASUNI C16 PIPE Malossi MHR RHQ 12mm Crank Athena Evolution 70cc 12mm cylinder kit Polini Evolution Big Valve Intake Malossi 13/44 final drive gear Stage 6 19 Mm Dellorto Carb Malossi delta clutch and Delta bell with Delta standard springs/weights and race springs /weights Malossi variator with Malossi Face plate Malossi Yellow Red Contras Top Performance Torque Converter Malossi Shim
Bando BWS 100 Belt 758 x 17.5
Post by ultramanmike on Sept 7, 2022 20:50:26 GMT -5
Post by ultramanmike on Sept 7, 2022 21:08:14 GMT -5
I'm also changing plastic color..
Post by Zino on Sept 7, 2022 21:39:03 GMT -5
Congrats on the prebug Setting your sights on running with the big boys .
The Athena Evo and C16 is a proven winner . You are going to have a hard time keeping the front tire on road at launch
Post by ultramanmike on Sept 8, 2022 6:04:16 GMT -5
Congrats on the prebug Setting your sights on running with the big boys . The Athena Evo and C16 is a proven winner . You are going to have a hard time keeping the front tire on road at launch Thanks Zino , I appreciate all your input already with picking parts for this build and also helping me dial in the bugeye ! I'm excited about this build
Post by ultramanmike on Sept 9, 2022 7:31:16 GMT -5
Ordered a few in-between main jet sizes for this build.
Post by ultramanmike on Sept 9, 2022 14:01:44 GMT -5
Sandblasted the fuel tank... now for some paint!
Post by Zino on Sept 9, 2022 14:27:16 GMT -5
If the inside of the tank is rusty
I use a sleave of bee bees from my bb gun to clean it up Just pour them in the tank
Shake it like a tamborine and then pour out the rust and the bbs .
Post by ultramanmike on Sept 9, 2022 15:17:12 GMT -5
If the inside of the tank is rusty I use a sleave of bee bees from my bb gun to clean it up Just pour them in the tank Shake it like a tamborine and then pour out the rust and the bbs . The inside is perfect! Just had some surface rust on the outside.
Post by Zino on Sept 9, 2022 17:14:36 GMT -5
Until your other parts engine parts come in To improve your ride .
The parts I sent to you should aarive monday night The Malossi Variator would work with your stock belt . Until you put a better pipe on you will probably need around 6-7 gram weights .
You will need the Delta clutch and Carb after you put on your power parts .
Post by ultramanmike on Sept 9, 2022 19:54:50 GMT -5
Until your other parts engine parts come in To improve your ride . The parts I sent to you should aarive monday night The Malossi Variator would work with your stock belt . Until you put a better pipe on you will probably need around 6-7 gram weights . You will need the Delta clutch and Carb after you put on your power parts . I threw this in , it runs 43mph with 7 gram weights scooterswapshop.com/products/top-performances-zuma-gp-trophy-cvt-kit
Post by ultramanmike on Sept 11, 2022 11:54:51 GMT -5
Post by ultramanmike on Sept 11, 2022 12:18:14 GMT -5
Post by Zino on Sept 11, 2022 12:57:57 GMT -5
Those ports are huge Just a little casting to polish up in the exhaust port so it really flows When you get your pipe you can match the exhaust port to the pipe
Post by ultramanmike on Sept 11, 2022 14:30:05 GMT -5
Those ports are huge Just a little casting to polish up in the exhaust port so it really flows When you get your pipe you can match the exhaust port to the pipe Looks really good, doesn't need much work at all !
