slawenm
Post by slawenm on Dec 3, 2011 7:14:47 GMT -5
thought I'd make a thread show how am going with rebuilding that blown engine, got most the parts through the post today the new parts look alot better than the last ones I bought. first thing I did was open box and snap shot the shiny new parts all ready gapped and installed piston rings on this pic. Edit: was about to chuck box and found an exhaust gasket lurking in the bottom will save me a few pounds very wet and cold outside so wont be doing much more today.
slawenm
Post by slawenm on Dec 3, 2011 8:49:09 GMT -5
Forget that been told to just fill it with oil and tip it out the hole the piston goes into instead.
I can see three larger bits of metal that wont come out of the oil drain so trying to pour them out of where the crank is, however oil drains too slow and with each flush they are barely moving I need to quickly fill and flush it to get them out I reckon.
I know I need something thinner to flush with and.... I know Brent suggested kerosene in another topic but I've heard this stuff can ruin the oil seals and bearings etc how true is this?
Post by 190mech on Dec 3, 2011 17:58:47 GMT -5
Kerosene will not hurt the bearings or seals!I've used a pump up garden sprayer for years to flush engines...
slawenm
Post by slawenm on Dec 4, 2011 15:40:13 GMT -5
slawenm
Post by slawenm on Dec 5, 2011 18:44:53 GMT -5
Post by reveeen on Dec 5, 2011 19:30:20 GMT -5
1) when the hole in your head (where the intake mounts) is only 18mm a 22mm carb is not going to end up doing much.
2) An up-gear kit is a good idea, but only if you have no troubles pulling the stock gears.
Both items you have linked to are, well, not quite as cheap as they should be..... SHOP AROUND!
zedooo
Post by zedooo on Dec 6, 2011 4:26:51 GMT -5
Yeah little carbs have much better airflow... Maybe it would be a good idea to get a small-diametered GOOD flatslide carb? (like Mikuni)?
Post by reveeen on Dec 6, 2011 8:44:21 GMT -5
"Being one to talk", I have a 24mm on mine, but in my case it was a matter of using what I had hanging around, if I was to "buy one in" it would be smaller.
slawenm
Post by slawenm on Dec 6, 2011 13:40:59 GMT -5
the prices are from the UK only places I can find cheaper gear ups or larger carbs are from USA and the price in postage makes up the difference + is the risk of having to pay the taxes and duties on the items too.
but thanks for info I'll buy a better 18mm carb with an accelerator pump on most likely. my engine will be 72cc again when I last had it 72cc it had more than enough power to pull taller gears at least it felt that way.
slawenm
Post by slawenm on Dec 10, 2011 12:45:34 GMT -5
Okay shes once again alive I've down jetted the carb because it was bogging running way too rich. I bought a brand new Iridum NGK spark plug but it seems to be faulty bike wont fire off it but if I take it out of head and put it on my HT boot and to the frame it shows a spark. very odd... not happy anyway cost 3x as much as a normal NGK plug. fitted this new varitor today with the 5.8g weights gave a gps confirmed 5 mph increase so well worth the money for me my back wheel seems to be spinning freely no matter how high or low I set my idle, the only thing I can come up with is clutch related and most of all springs, time for a set of tougher springs in there or maybe lighten it?
Post by 90GTVert on Dec 10, 2011 13:55:37 GMT -5
Springs or lightening the shoes should help with the tire spin assuming the idle is set to the proper speed. Something like 1900RPM. If you have a scoot with a parking brake, you can set that to stop it.
slawenm
Post by slawenm on Dec 10, 2011 14:22:12 GMT -5
my tach is completely shot so not sure on the speed but I set it by ear as I always have just seems with this new kit + varatior it wont stop spinning until the idle is so low the bike is spluttering with very dim lights.
Post by 90GTVert on Dec 10, 2011 15:56:02 GMT -5
That kit should come with a spacer that fits on the drive boss. You could try using that. Might free the belt up at idle instead of squeezing it in the vari.
slawenm
Post by slawenm on Dec 10, 2011 16:14:29 GMT -5
aye it has a like 1mm spacer with it, I didnt know what it was for so left it off, will that tiny thing knock my top speed down?
Post by Deleted on Dec 10, 2011 16:53:32 GMT -5
WHAT SIZE BORE IS THAT ANd where did you get the variator?
