Post by tgblasermod on Sept 9, 2022 19:58:43 GMT -5
Greetings I’ve recently just purchased a TGB laser r5 2t I’m looking into a 70cc an technigas exhaust an bigger carb. Anyone with experience with Morini style engines an tips that could help me or point me toward a good build would be appreciated im having trouble finding any performance parts. Thanks in advance
Post by Zino on Sept 9, 2022 21:08:33 GMT -5
Here is a great vendor that stocks parts for your TGB www.scootertuning.ca/en/21002-tgb-r50xTGB You have good choices for 70 cc kits Malossi Sport and Polini Sport are proven for Long Term Reliability and Extra power. Pipes This is where your choices narrow 2 Choices Tecnigas street pipe that will give you extra spunk and you can run stock cvt settings you will get a few more mph You may need to up jet the carb and you might like lighter weights and stiffer clutch springs then stock Tecnigas Next R for Loud and Proud 2 stroke sound and extra speed over the Silent Pro You will have to rejet the carb and you will need stiffer clutch springs and weights to get up in the power band otherwise it will feel very doggy and then when it catches up it will feel like you hit the turbos To protect your hard work I would add a Temp gauge to your build list Trail Tech makes a good one that fits on the spark plug .
