Post by abansb on Dec 7, 2011 15:17:14 GMT -5
I am not sure if this is the problem but one of my scoots it is acting funny like it is stuck in low gear my guess is maybe the clutch spring is wore out I am not for sure if the clutch is working right not for sure how to tell
The old engine I had on it felt like it would change gears up and down but this one doesn't do that is there anyway to check to make sure the clutch is working properly without riding the scoot
Thanks
Post by ososlow on Dec 7, 2011 17:48:14 GMT -5
you could take the cover off and watch the cvt do its thing
Post by Deleted on Dec 7, 2011 17:52:49 GMT -5
sounds more like the variator or torque sheave. you will have a hard time starting it with the cvt cover off if its a qmb since the cvt cover has to on for both the kickstart and electric start to work.
Post by ososlow on Dec 7, 2011 18:25:36 GMT -5
i usually just take all the bolts off, leaving the 2 bolts closest to the starter gear hand tight, start it, then remove those last 2 and pop the cover off
Post by abansb on Dec 18, 2011 18:14:21 GMT -5
Ok I got around to doing like Ososlow suggested the belt is going up the variator about 1/4 inch from the top and the belt going up on the clutch about 1/2 inch from the top of the clutch when I rev it up almost looks like the belt is evenly on the variator and clutch.
But the clutch is working not for sure like it is suppose to
Thanks again for the help
Post by Fox on Dec 18, 2011 18:58:43 GMT -5
Post by Pony66 on Dec 21, 2011 10:46:36 GMT -5
But the clutch is working not for sure like it is suppose to The sliding parts on the clutch have probably dried out. There is a thin sleave on the back of the clutch pulley. Use a screwdriver and gently take the sleave off. Under there it needs grease. The outer pulley slides on three pins. You can pop the pins out real easy. Pull the sliding sheaves apart and grease inside. Put them back together, put pins in and grease the tracks. Pop the cover sleave on and your done. Oh clean the pulleys very well.
Post by Fox on Dec 21, 2011 17:27:50 GMT -5
Post by abansb on Jan 11, 2012 14:50:56 GMT -5
I got the problem fixed the belt was slipping I replaced the belt and no hesitation what so ever
I put the belts side by side the one I took off was an inch longer same size wrote on the belts
