Post by metalman on Nov 18, 2022 13:08:49 GMT -5
Post by geoffh on Nov 18, 2022 15:12:07 GMT -5
Welcome to the forum,we will need a little more info to really help,2 stroke or 4 stroke,year and pictures of your carb,what leads you to believe a new carb is needed,tell us the story.carbs have a long service life if looked after and are usually bought as an upgrade.
Post by metalman on Nov 18, 2022 17:06:44 GMT -5
Post by metalman on Nov 19, 2022 10:36:38 GMT -5
I have an update. Went out this morning and got it started. But when I try giving it gas it bogs down. Maybe a ground problem? Any help is appreciated
Post by aeroxbud on Nov 19, 2022 12:22:16 GMT -5
I would try cleaning the carb before buying a new one, if it was running okay before. There are quite a few videos on YouTube if you are not sure about doing it.
Post by metalman on Nov 19, 2022 13:59:50 GMT -5
I understand, unfortunately I have very limited resources, am disabled and this is my only form of transportation. Thanks for the info though. I appreciate it, guess I'll just keep tinkering
Post by geoffh on Nov 19, 2022 14:44:33 GMT -5
If you are reluctant to delve into the carb you will need a direct replacement,I think your cabo is a sym scooter underneath so parts should be plentiful and cheap I would contact partsforscooters, they are members of this forum and will help you out,but if your scoot sat through a hurricane the fuel may need changing.keep on asking.
Post by metalman on Nov 20, 2022 15:50:00 GMT -5
Post by aeroxbud on Nov 20, 2022 15:57:00 GMT -5
Post by metalman on Nov 21, 2022 8:21:31 GMT -5
Says on the site it's for a 4 stroke. Only thing I wasn't sure about is the metal wrapped line, looks like a bowl drain line to me. If it doesn't work I'll return it and try the link you sent. Thanks for your help
Post by metalman on Nov 23, 2022 15:12:48 GMT -5
Turns out it was a wiring problem. I got some parts on Amazon and the coils wires were lose. I tightened them up and it started right up and seems to be running alright. I do have another issue though, it seems that I have a lose connection going to my digital dash. At times it completely goes out and comes back on. Guess I'll have to check the wiring again. Anyone have any idea where the dash gets its info from? Not sure that's the problem but can't hurt to check it. Can't tell you how excited I am to have my scooter running again. Monday I had to pay someone 40$ to take me to class and shopping 🛍
