oops
Dec 8, 2011 10:33:54 GMT -5
Post by Deleted on Dec 8, 2011 10:33:54 GMT -5
The sweet bike i built in the PDI thread I made is here it has Diesel Fuel in it. I had another come to me with Diesel in it and i cleaned it all out but it ended up burning a valve anyway. Sad.
oops
Dec 8, 2011 10:47:35 GMT -5
Post by 90GTVert on Dec 8, 2011 10:47:35 GMT -5
I always thought that all adding diesel to a gas motor would do in most cases was cause poor running or no running. I dunno, the pumps are all clearly labeled so I can't say I've ever been in so much of a hurry or whatever that causes people to accidentally fill up with diesel fuel.
If you drain the fuel system, including the bowl of the carb, I can't see why you'd see any symptoms from adding diesel to the tank.
oops
Dec 8, 2011 10:55:25 GMT -5
Post by Deleted on Dec 8, 2011 10:55:25 GMT -5
My father was very preoccupied with a family issue once and he put Diesel in our 72 VW once too. It didnt last long after that either.
Putting Diesel in a Gas motor is supposedly not as bad as putting Gas in a Diesel motor but the ones I have been around didnt last after that. I guess they were about to go out anyway. I will clean it out and get paid, they can hope for the best.
oops
Dec 8, 2011 10:56:47 GMT -5
Post by Pony66 on Dec 8, 2011 10:56:47 GMT -5
How did somebody ship something with fuel in it? Diesel should just smoke a lot and lube the valve. I would think the plume of black smoke might be a clue to turn the scooter off. Running an open air filter and not jetting properly and changing in the summer and winter, that would burn a valve or piston real quick.
oops
Dec 8, 2011 10:57:59 GMT -5
Post by Deleted on Dec 8, 2011 10:57:59 GMT -5
Sometime in the late 70's - early 80's they started making the diesel pump nozzle bigger than gas pump nozzles and putting a thing in the filler neck where a diesel pump wont go in it, too bad chinoscoots dont have that.
oops
Dec 8, 2011 11:09:28 GMT -5
Post by Deleted on Dec 8, 2011 11:09:28 GMT -5
How did somebody ship something with fuel in it? Diesel should just smoke a lot and lube the valve. I would think the plume of black smoke might be a clue to turn the scooter off. Running an open air filter and not jetting properly and changing in the summer and winter, that would burn a valve or piston real quick. lol no no it was sold to a customer. it was built in the first place for a customer.
oops
Dec 8, 2011 11:10:49 GMT -5
Post by Deleted on Dec 8, 2011 11:10:49 GMT -5
and when i said 'come to me' i meant a customer brought it to me lol no they were not shipped from china with diesel in them lol the new owners put it in there by mistake.
oops
Dec 8, 2011 11:15:54 GMT -5
Post by Pony66 on Dec 8, 2011 11:15:54 GMT -5
and when i said 'come to me' i meant a customer brought it to me lol no they were not shipped from china with diesel in them lol the new owners put it in there by mistake. Ok, now I understand. I only put diesel in my old Chevelle once because I was out of gas and used it. It was in a gas can at the shop. Then my Dad told me it was diesel after I fogged the country all the way home.
oops
Dec 8, 2011 23:32:27 GMT -5
Post by jmkjr72 on Dec 8, 2011 23:32:27 GMT -5
Sometime in the late 70's - early 80's they started making the diesel pump nozzle bigger than gas pump nozzles and putting a thing in the filler neck where a diesel pump wont go in it, too bad chinoscoots dont have that. the ones for rigs are larger but the ones on the car pumps are the same size more then once at my friends station did we have people pull up to the pumps out back (the diesel pumps) and people fill cars up and then wonder why it would die before the got out off the station and these were 90s and 00s cars
oops
Dec 8, 2011 23:44:46 GMT -5
Post by Fox on Dec 8, 2011 23:44:46 GMT -5
I can't see how diesel fuel would cause a long term problem or cause an engine to wear out faster than normal. If you flush the fuel tank well and clean the carb it should run just like it should right?
oops
Dec 8, 2011 23:51:34 GMT -5
Post by Deleted on Dec 8, 2011 23:51:34 GMT -5
I can't see how diesel fuel would cause a long term problem or cause an engine to wear out faster than normal. If you flush the fuel tank well and clean the carb it should run just like it should right? yeah it should. the 2 engines i have direct knowledge with didnt last long after this happened to them but maybe it was a weird star crossed coincidence.
