Post by yamahahaha on Nov 28, 2022 4:16:42 GMT -5
I have a 88 Yamaha razz runs amazing got it from a friend he had it in his garage for 30 years I had it 15 minutes had it running but I took off the air filter and replaced it with a sock and it runs top speed the needle goes all the way down to the m on mph pass the 30
Post by geoffh on Nov 28, 2022 16:02:58 GMT -5
Welcome to the forum,nice find but put your sock back on and refit the air filter,you will be running lean and your engine with over heat in short order,post a picture o your filter assy ,it may have restriction you can remove and upjet your carb for safe running.
