Post by coachhejl on Dec 11, 2022 12:10:39 GMT -5
My scooter had a pcv canister.
I'm rebuilding the head and forgot where one of the lines run.
So the air breather connected to it.
There is a barb that's labelled "pcv" on it.
There is also a barb that's labelled "A" and "T"
There is a vacuum host that comes from carb on end close to reed valve...is that pcv?
There is also a hose that routs up towards like the gas tank somewhere. Then it hooked to the canister but not positive where it ultimately goes.
Anyway...can I simplify this system and do away with it?
If not, where do they hook up on the canister?
Also, I am installing a manual petcock so I do not need the vacuum from wherever that one comes.
Any and all help would be greatly appreciated.
Post by aeroxbud on Dec 11, 2022 14:23:34 GMT -5
It would be a help if we were to know what bike. Or if you put your current bike in you're signature.
Post by coachhejl on Dec 11, 2022 15:54:55 GMT -5
Vento Triton gt5. It would be a help if we were to know what bike. Or if you put your current bike in you're signature.
