New carb
Dec 22, 2022 11:42:49 GMT -5
via mobile
Post by coachhejl on Dec 22, 2022 11:42:49 GMT -5
Alot of them come with the small air breather.
If you use this, do you disable the stock big one?
Post by GrumpyUnk on Jan 5, 2023 11:03:41 GMT -5
What part are you referring to with 'small air breather'? If it is the tube on the leading/forward end of the factory air cleaner, then two things to consider. The external part has a screen and multiple holes for incoming airflow. The internal part is a pretty small diameter plastic assembly that may just be a little restrictive for a BBK The diameter seems close to that of the venturi feeding the engine, but likely will only add some noise if removed and it should not cause any problems of operation. So... what part? Or are you referring to something else? tom
