Post by noxalm on Dec 29, 2022 3:20:01 GMT -5
Post by aeroxbud on Dec 29, 2022 6:06:45 GMT -5
Welcome to the forum. That carb is not a real 20mm carb. It is just machined out to look like it is. Exhaust is not available anymore. You don't really need to upgrade the stock exhaust on a GY6, as they are not restricted. I don't know anything about that kit though.
Post by GrumpyUnk on Dec 31, 2022 11:15:38 GMT -5
GOOFIT and GLIXAL have been selling for years on both of the big two. They also are selling on aliexpress. If you want relatively easy return conditions at a bit higher out the door, stay stateside. They both sell items that are good, and items that may be a bit questionable. Replacing both head and cylinder when going BBK keeps the compression ration within reason when going to the largest bore possible. The kit does not mention the diameter of the piston & cylinder... 72cc or 83cc or 63cc... who knows. Most have found the 47mm/72cc cylinder/piston to work acceptably with the original cylinder head. I have not heard or any complaints using the original. Be aware that this kit is for 64mm length valves. It will not work with the other length. I do not know why that is mentioned as the head, cam, rocker arms ..... never mind. No cam. The cam may be specific, though I do not think so. The diameter is given in the pictures - 50mm. Performance to expect is an unknown, but I have gotten 72cc kits - 47mm - to go 40mph. Maybe. Did not have a GPS to check, and speedo was buried. tom
