Post by rollingbender on Jan 7, 2023 14:32:32 GMT -5
I have searched and searched and google has been no friend.
I’m looking for a 10” rim for a short case 150cc. A 50cc rim has the correct splines and brake drum but the offset of the rim is wrong. It looks like it needs to be dished out about 1” so that the rim is centered correctly in the case opening.
Where do I find this?
sinfull
Post by sinfull on Jan 7, 2023 16:13:13 GMT -5
Most just use a spacer to space the rim off the case, and a spacer to fill in the bolt side since most gy6 150 are long axle for dual shocks.
Are you doing a 150 swap and using the qmb139 rear wheel ??
Post by rollingbender on Jan 7, 2023 20:21:26 GMT -5
A spacer would get the 50cc rim centered but would not be good for the drum brake’s operation.
Post by 90GTVert on Jan 10, 2023 18:45:30 GMT -5
