Post by utchieutchie on Jan 8, 2023 1:01:33 GMT -5
Hello guys. Can someone share whats the head volume (cc/ml) of the 100 2fast 100cc cylinder head or the malossi 94/100c. Would like to test it to my all steel 95cc race engine. Thanks in adv.
Post by Lucass2T on Jan 8, 2023 3:52:18 GMT -5
Google: 'Compression ratio Malossi rc-one'. The very first hit is a link to this forum where Brent has listed all the specs (including head volume and compression ratio) for the Malossirc-one. Good luck.
Post by 90GTVert on Jan 9, 2023 7:32:01 GMT -5
Google: 'Compression ratio Malossi rc-one'. The very first hit is a link to this forum where Brent has listed all the specs (including head volume and compression ratio) for the Malossirc-one. Good luck. Nice. He sent me an email with the same question and I said I didn't know cause I hadn't measured the only 94cc high end I've owned. Totally forgot that was in there. www.49ccscoot.com/rc1.html#specs6.9cc with 14.6:1 UCCR That's LC info. I would think head swaps could be an issue for LC stuff since many have different dimensions to work with the shape of the cylinder and outer head. AC should be less problematic, but I don't know if there's any difference in an AC chamber volume.
