Post by 2tdooby on Feb 24, 2023 15:55:49 GMT -5
I have an ‘01 disc brake zuma. The front forks are shot and need replacing. I am unable to find any OEM replacements, and am not sure if anyone makes an aftermarket version. ScooterSwapShop does have some kind of shim kit, but am not sure if i am looking at the right thing, and if so would I need kit A or B. If so would they work with these legs, and what else would I need, to keep everything OEM as far as brakes and wheels go. Any help would be greatly appreciated! scooterswapshop.com/products/yamaha-jog-zuma-prebug-dio-ruck-fork-shim-kitscooterswapshop.com/products/ncy-10mm-dio-legs-sym-dd50I am making this post of a phone so sorry if links do not work i will relink when i get home.
Post by hippo008 on Feb 24, 2023 16:12:57 GMT -5
If you buy kit A that would indicate you are going to use NCY or similar legs in a stock tree. If you buy the secocnd kit you are intended to use OEM legs inside a 30mm aftermarket tree like the NCY or similar Dio tree off ScooterTuning.ca or AliExpress.
In terms of legs you will need to buy the NCY Dio legs. I dont think the caliper or caliper bracket will work with those legs. I think you will need to purchase a specific Dio caliper and bracket. I suggest the 180mm JISO setup, they arent cheap but they work the best and allow the most clearance around the rim.
You could run a 200mm setup with NCY bracket but you will need to space the wheel out appropriately.
Post by aeroxbud on Feb 25, 2023 8:53:25 GMT -5
Post by yambw’s on Feb 25, 2023 14:39:53 GMT -5
You can check mine out but I’m not entirely sure you can still get them, you might have to do some research. EBR is the manufacture. They are not as good as a hydronic set like aeroxbud recommended tho. And I have just realised you have the disk set up so I’d go for the BWS mk11 forks
