I'm sure it's possible to enable it, but it might take a good bit of re-wiring. My 90cc Triton came with a switch with just a starter button and I wired it to a new style Triton switch with the light switch. Takes a goo d bit of probing to see what's what but it can be done.
Here's the post I made when I did that. Not sure that much applies here, but just in case...
"When I ordered a new brake lever, I ordered the one like my other Triton uses. It includes a parking brake. I ordered a complete LH assembly and already had a RH assembly around. My US version Triton has more headlight functions as well as a kill switch. The US version allows you to turn the running lights on, headlight, hi/low/pass switch, starter button, and includes a kill switch. The Mexican version's lights are on anytime the bike is on, have hi/low switch, and a starter button. I've been putting this off for some time, but I decided to wire this all up today. It's not a plug and play setup unfortunately.
Here are the RH controls. Top is the new one.
Here are the LH controls. Top is the new one.
This is a lighting controller of some sort that the R3/Mexican Tritons use. Newer versions don't use this.
I had to chop up both harnesses for each side and solder the appropriate connectors on.
Installed on the scoot and put the panel back on.
Here's a little list of what wires I had and what I modified. May be of some use if anyone else does something similar. I think you can figure it out with this and looking at the pics.
R3/Mexican LH ControlConnector 1 :[/b] Cut off (leave 2" of wire) to use on R4 LH control.
Blue (Lighting System)
Light Blue (Lighting System)
Connector 2 : Cut off (leave 2" of wire) to use on R4 LH control.
Yellow/Red(Lighting System)
Green/Black (L Turn Signals)
Green/White (R Turn Signals)
BlackBrown (Horn)
Orange (Flasher)
R4/Amereican LH Control
Connector 1 : Attaches to connector 3 of R4 RH control.
Yellow/Red (Lighting System)
Connector 2 : Cut off.
Blue (Lighting System) Attach to
Blue[/b] wire on connector 1 of R3 LH control.
Light Blue (Lighting System) Attach to
Light Blue[/b] wire on connector 1 of R3 LH control.
Yellow (Lighting System) Attach to
Yellow wire on connector 2 of R3 LH control.
Green/Black (L Turn Signals) Attach to
Green/Black wire on connector 2 of R3 LH control.
Green/White (R Turn Signals) Attach to
Green/White wire on connector 2 of R3 LH control.
Black (Ground) Attach to
Black wire on connector 2 of R# LH control.
Brown (Horn) Attach to
Brown wire on connector 2 of R3 LH control.
Orange (Flasher) Attach to
Orange wire on connector 2 of R3 LH control.
R3/Mexican RH Control
Connector 1 : Cut off (leave 2" of wire) to use on R4 RH control.
Green/Yellow (Starter)
Purple (Starter)
R4/American RH Control
Connector 1 : Cut off.
Green/Yellow (Starter) Attach to
Green/Yellow wire on connector 1 of R3 RH control.
Purple (Starter) Attach to
Purple wire on connector 1 of R3 RH control.
Green/Red (Magneto Power) Attach to
Green/Red wire from R3 lighting control box wiring.
Yellow wire from R3 lighting control box.
Connector 2 : Black (Kill Switch)
Black/White (Kill Switch)
Connector 3 : Attaches to connector 1 of R4 LH control.
R3/Mexican Lighting Control Box
Red/White (Ignition Switched Power) Not used. Wrap in electrical tape or removed from system.
Green/Red wire from R4 RH control.
Black (Ground) Not used. Wrap in electrical tape or removed from system.
Yellow wire from R4 RH control.
Blue/Black (Lighting System) Not used. Wrap in electrical tape or removed from system.
Everything works but the passing light (turns on both high and low beams momentarily). That doesn't really worry me, I mainly wanted the ability to turn my lights off and have a parking brake. I havent hooked the kill switch up yet. I believe there is a connector by the CDI for it, so I'd just need to run the wires up to the connector on the handlebar.."
Here's a wiring diagram form an R4 that has a working switch.
www.49ccscoot.com/r4iwires.html
