Post by br4inl3ss on Apr 30, 2023 20:13:15 GMT -5
hi
its me ocne again. with another problem.
whait. what ? how did you know idd come back with another issue....
its not like i had 3495763057245389 issues.... oh wait. i do.
well... i found the metallic noise. the variator boss is loose in the variator bushing, allowing the variator to wiggle alot.
fine. too much money spent on the full rebuild, ill buy a variator later on.
actual issue, is an electrical one.
ive had this issue since a long time, but people said ti was the battery then the starter then the relay.
brand new starter, new starter ( 1 month, didnt even turn for 30 second total yet ), brandnew relay ( installed 4 days ago, tested today ), new wiring harness ( scooter did about 2 km with it ).... we can say tis all brand new, right ?
with whatever battery ( my old 7ah, my unknown-age 7ah battery but seems to work good even load test good, my brother vino 4ah battery, my brother vino actual 6ah battery ). if the battery is full at 2.5/2.6v, it turns over but not fast enought to start untill its hot.
if bettery is at 2.12 or less, then voltage drop ( 9 to 10v ) and starter barely turn. when at 9v it wont even turn at all not even slowly.
the vino 4ah battery ( yup its a smaller battery but its in perfect condition and almost new ). it crank the vino like a red hot & sharpened katana in butter ( is this hot and sharp enought ? ). my 8ah battery can be charged at 12v, tested 12.5v on the scooter up untill i try to start it. voltage drop to 11v when cranking, and battery voltage drop very fast. i cant even hold it for 10 second and the battery will drop voltage to 9v, even if i stop cranking and voltage will never go up untill i charge it overnight on a Norco charger ( nope not in automotive mode. that would kill any small battery ).
i tested for parasitic draw, none ( 0.0016 amp with key on without headlights ). cannot test amp draw while cranking i dont have that tool. multimiter is limited to 15 amps. but i get 0.420 amp draw with headlights ( dual H4 LED ). thats including the +/- 0.0200 amp draw from the rectifier regulator ( 7 wire, 11 pole stator upgrade ).
btw the battery voltage drop happen without headlights. i tought it was it but nope.
it look like whatever starter ( old and new ) i use it will drain battery in a very fast manner ( 1-3 try with 4ah battery and about 10 try with proper size 7ah battery ).
i'm about to test with a car battery... sadly this is just a test with no revelent results.
the wire from battery to starter relay is not new but tested good. even on a totaled car i have access to. all the rest is new even the damn engine.
EDIT:
ive seen it charge the battery to 17-19v at high rpm testing the engine the other day but that was my old 7ah battery. ive been told that a dead battery can cause the regulator to not sense the battery voltage hence overcharging it.
also been told it could happens with no load ( headlights off ). it was also with old 7ah battery. with the 4ah vino battery the voltage went up to 16.1 with headlights unplugged, didnt go over 14.6 with headlights plugged. i guess they're right about load.
EDIT:
