Post by 808ministroke on May 3, 2023 13:18:46 GMT -5
I have been running this idea in my head for quite some tim. I think it all might stem from the backed at my front radiator on one of my mopeds Came off of one of my dad's super computers that hes buddy built Out of commission of course I would never just dissect a flawless machine One more thing about that computer the large radiator that was mounted towards the very top of the huge case it's had 4 fans that wereSilent as f*** 2 on the bottom pushing air through and 2 on the top pulling which took up exactly the area of the radiator itself so OK on to my radical idea.
Well mostProcessors aren't or weren't water cooledAs a matter of fact graphics cards which probably demand more power and therefore cooling then the CPU itself are very rarely even still liquidLiquid cold. However over the years they have devised some pretty interesting cooling mechanisms for those graphics cards as in multiple copper rails which I believe have some sort of oil in them Along with a vast amount of fins and a good amount of fans all put together in a way where the air was either pulled in from one side and pushed out the other, I think this is called a blower I think this is called a blower Or else getting circulated in the same direction before the films Or else getting circulated in the same direction They cool the GPU's chip by a contact point which The one I'm holding A&E VGA G force GTX770 Is a copper plate directly directly bolted on top of the copper pause witch Extend out to the cooling fins on both sides with a fan above either side, Thermal paste is used to add here the chip to this copper plate.
What If I ground down the side of a cylindor even ahead for that matter that was air cool Adding probably triple the heat dispersion that the normal fins would add plus if I powered the 2 fans I would assume that the cooling could be just as much as from the forced air cooling they already have So my theory is if this were done one might be able to get twice the cooling capabilities off of an air cooled cylinder for a pretty cheap seeing as a parts card would be a couple bucks all you would have to do is hook up the fans to a power wire which wouldn't be hard You can even usually control the fan speed if you wanted to does anybody think I'm on to something
