Post by petestix46 on May 16, 2023 18:18:15 GMT -5
Hi everyone.
firstly thank you for taking time to read my post. I have a 2017 piaggio zip that i am coverting to 70cc with a Direct Digital DD09 MVT ignition. ive wired the ignition in and it runs great however,iits not charging or working the lights. im left with the main fused wire that used to run to the stator. could you tell me where to put it please? Be nice lol
Post by aeroxbud on May 17, 2023 4:12:28 GMT -5
This might help.
Post by aragorn on May 18, 2023 4:21:37 GMT -5
Hello, Ive been dealing with the same problem few weeks ago, and I ended up following: bought yamaha 3GF-H1960-00 regulator (as suggested in Brent´s installation scheme), and I connected it as showed on picture (https://www.mopedarmy.com/forums/file.php?7,file=240980)... Afterwards, I removed 1 cable from original Piaggio rectifier which distributes AC power to lights and connected this cable directly to battery, so that my lights are no longer beam-dependant on RPM´s (Im using LEDs in front and rear lights). So now I have battery charging and lights in one pack.
