Post by stancejontland on May 19, 2023 21:18:51 GMT -5
getting some chatter on my ride home from work today. Sounds like it might be that bearing in the rear of the cvt. Let me know what you guys think.
Post by stancejontland on May 20, 2023 20:41:24 GMT -5
Post by rtnifty on May 21, 2023 0:11:21 GMT -5
Hmm. I cant figure out what that square piece goes to. Nothing broke off the inside of the cover did it? Did you check starter gear? If the bolts holding yhe gear get a little loose can cause a rattle.
Mine actually came completely loose once and rattled around the case. Scare the piss out of me.
Everything else looks okay. Belt doesn't seem to be showing any abuse. How loose was the cover? Was there a noticeable gap or it just wasnt tight?
Post by stancejontland on May 21, 2023 1:22:00 GMT -5
Just some of the screws were loose. Not loose but not very tight at all. Hmm. I cant figure out what that square piece goes to. Nothing broke off the inside of the cover did it? Did you check starter gear? If the bolts holding yhe gear get a little loose can cause a rattle. Mine actually came completely loose once and rattled around the case. Scare the piss out of me. Everything else looks okay. Belt doesn't seem to be showing any abuse. How loose was the cover? Was there a noticeable gap or it just wasnt tight?
Post by rtnifty on May 21, 2023 7:55:29 GMT -5
Yeah Maybe was enough to just kind of rattle things a little bit. That piece of metal is perplexing. Doesn't look like anything off of the CVT or on the cases side. That's really weird. How's it riding now? Still issue or is it okay? Did you run it with the cover off just to see if anything's wobbling about?
The black material do you mean the belt dust on the case? That does happen. Careful if you blow it out to clean it, s*** goes everywhere. Yours doesn't look bad at all that's not a lot of dust.
Post by stancejontland on May 21, 2023 13:17:38 GMT -5
I haven't ran it yet. Ill run it with the case off and take a video
Post by stancejontland on May 21, 2023 15:54:21 GMT -5
No sound coming from cvt with the cover off. I cleaned up the bearing and the housing it sits in. Threw the cover back on and the sound seemed to go away. At least just from spinning the rear tire on the stand. But in the video the belt seems to really be bouncing around. Is that normal?
Post by aeroxbud on May 21, 2023 17:03:36 GMT -5
That seems very excessive. Even when idling its jumping about a lot.
Post by rtnifty on May 21, 2023 19:12:30 GMT -5
Wooooow! That is some serious belt slap you got going on there. So the noise could be the belt hitting the top of the cover. How old is that belt? Might want to give it a measure just see if it's still within spec. If the problem is really just starting then the belt may have finally worn itself below spec width. The reason why I say this is it looks like it's really bouncing around when you start hitting higher speed. It could be that is the variators closing the belt might be a little thin so you're getting more wobble.
That's just a supposition though. Definitely give the belt a measure and see if narrower than it's supposed to be
Post by stancejontland on May 21, 2023 22:57:10 GMT -5
uhh the belt is maybe 2 years old but probably less that 100 miles on it? i didn't ride it at all last year. i broke the belt in September or august 2021 and fixed it when i got back from my trip. then haven't ridden it till this year.
Post by stancejontland on May 22, 2023 15:51:16 GMT -5
Ok so the sound came back today on my way to work. Maybe what im hearing is the belt slapping the cvt cover. Ill see if i can get it measured tonight after work. The belt isn't that old at all.
Post by aeroxbud on May 23, 2023 3:30:56 GMT -5
Of its not the belt, it could be the contra spring no longer keeping the belt under proper tension.
Post by rtnifty on May 23, 2023 6:35:00 GMT -5
aeroxbud That's a good point. Could be the spring. That might explain the rubberband sort of feel described earlier.
Post by oldgeek on May 23, 2023 7:05:08 GMT -5
In you last picture of your first series of pictures you can clearly see the variator is loose, the star washer is out of place and the broken piece came from the star washer. Crankshaft is likley trashed at this point.
Post by aeroxbud on May 23, 2023 14:41:32 GMT -5
