Post by Zino on May 31, 2023 16:28:02 GMT -5
The malossi sport is a solid cylinder I have put thousands of miles on them When you take the stock cylinder off you will see what is holding your rpm’s down the exhaust port is only open 2/3 of the way Your pipe with a malossi will push high 9000s to mid 10000 rpms
Post by Zino on May 31, 2023 19:15:57 GMT -5
here is a guy fixing the restricted exhaust port on a stock zuma so it was more free breathing and rev higher 500- 1000 more rpm But for a few more bucks and less overall work slapping on a 70cc malossi does so much more No replacement for displacement www.youtube.com/watch?v=cEeujuQDEJk&ab_channel=muffinflesh
