Post by redsea on Jun 8, 2023 17:41:41 GMT -5
Hello I have Yamaha Slider 2002
I have tried to set upp my variator and i have tested weight from 3 gram+6=18 gram To 5.5 gram+6=33gram and all in between to find something that works. But i still have about 10 mm left on the front variator and i tested shims different slot angles rear pulley 38 and 41 but no different
I wonder if any one have same problem and wonder if i have the wrong belt In the manual it says long minarelli S6-591667 belt And short minarelli S6-591668. But i bought all as a kit and hoped it should worked out but i cant get the belt all way up So i wonder if i got wrong belt or any other idea ? Sorry for the long text Best regards Steve
MXS RACING 70CC 196°/132°/134°). MXS RACING EXHAUST v 2 MXS RACING BIGVALVE VFORCE 3 REED STAGE6 MK 2 HPC CRANK SKF C4 NT9 BEARING POLINI LOW FRICTION VITON BEARING SEALS POLINI PWK 28 MM CARB 165 MJ STAGE 6 Red racing AIRFILTER MVT INTERNAL ROTOR IGNITION PREMIUM DIRECT MVT IGNITION COIL MVT DIGITAL EPROOM CDI Denso iwf 27 spark plug iridium NGK RACING LINE WITH spark plug cap silicon (malossi racing) STAGE6 MK 2 CLUTCH STAGE6 R/T OVERSIZE CVT-VARIATOR KIT MK II D=107MM. Stage 6 oversize belt S6-5916627 that came with the kit. STAGE6 R/T CLUTCH BELL 433G. STAGE6 PRIMARY TRANSMISSION GEARING POLINI RACING GEAR COVER EXSTRA BEARING WITH VITON SEALING POLINI RACING SWING ARM Cromed OVERSIZE- VARIATOR Stage 6 MK2 RPM TEMP READING
Post by Zino on Jun 8, 2023 18:54:40 GMT -5
Post by redsea on Jun 9, 2023 4:18:53 GMT -5
Yes it is How do i show pictures?
Post by redsea on Jun 9, 2023 4:34:07 GMT -5
If i use light weights rpm is 13500 If i use heavy about 12800 And about 20 gram 11500-12500 rpm and max out about 13500 rpm But still always the same marks on the variator use a black ink to mark Misding about 8 mm
Post by redsea on Jun 9, 2023 4:35:19 GMT -5
Post by redsea on Jun 9, 2023 4:36:05 GMT -5
Post by redsea on Jun 9, 2023 4:36:51 GMT -5
Post by Zino on Jun 9, 2023 6:05:28 GMT -5
on your first picture did you mark variator all the way to center to see if you get all the way to the bottom your back pulley looks to also have 8mm left can you post a picture like this this is a fulley maxed rear pulley
Post by Zino on Jun 9, 2023 6:18:26 GMT -5
for shiming to get full belt travel on the bottom for best take off i only need one shim or no shims in this pictire i have to many shims you want the edge of the belt to just get to the edge of the drive boss . lucass2t and aeroxbud might have a little more knowledge on the stage 6 stuff
Post by redsea on Jun 9, 2023 16:07:18 GMT -5
Thanks I take Pictures in morning and put up Best regards steve
Post by redsea on Jun 16, 2023 14:13:50 GMT -5
Post by redsea on Jun 16, 2023 15:07:49 GMT -5
Post by redsea on Jun 16, 2023 15:10:02 GMT -5
Post by redsea on Jun 16, 2023 15:12:22 GMT -5
I locked the front pulley and took away the tork spring and it looks like the belt is perfect size But i cant get it to go all way with light weight and heavy weights Or is the power to low to make it go all way But it feels like going really strong In 11700-12500 rpm range
Post by aeroxbud on Jun 17, 2023 13:57:25 GMT -5
That's defy the right belt for the long case. I had this setup on my old aerox with a similar race cylinder. I seem to remember I never got it to the very edge, but it was close. What final drive ratio are you running?
