Post by thebullet92 on Jun 11, 2023 16:01:57 GMT -5
Hello everyone, I am after an upgrade head for this, I had an issue with it which caused the piston and head to be scrap. So the head I am looking to replace allows carb and exhaust to fit to it. I can only find ones with exhaust fitment, the rest looks like carbs to engine casing. can anyone point me in the right direction please? [/URL] [/URL]
Post by snaker on Jun 12, 2023 8:31:04 GMT -5
Sounds like what your describing is that your engine has the carb attached to the cylinder and the replacement parts your finding are for a crankcase inducted 2 stroke engine? I would think that there should be something out there in the scooter world to meet your needs. Whether different brands will fit is another thing. Have to match the base dimensions and the rod length
At some point it might be easier to do a full engine swap.
Post by thebullet92 on Jun 12, 2023 10:23:32 GMT -5
This is indeed correct,
I have found a couple of heads but find there is only 2 holes on the carb intake instead of 4 and slightly different shape
Post by thebullet92 on Jun 12, 2023 11:49:54 GMT -5
