Post by awines2326 on Jun 15, 2023 10:43:42 GMT -5
I'm at a point where I'm stumped on my build. I am starting on all of the electrical on my Piaggio Typhoon & my brand new MVT ignition is not producing power. Is there something that could be causing the issue that I am overlooking or did I just get a bad ignition? The electrical is working off the battery, and I've gone over the wiring diagram for the ignition 100x and everything is proper but when I kick the thing there is no electrical output...
Post by awines2326 on Jun 15, 2023 11:07:03 GMT -5
If I check resistance on the wores coming from the "stator" I get between .1 - .4 on all wires except the power wire I'm getting 155.
Post by awines2326 on Jun 15, 2023 11:39:57 GMT -5
Maybe its not an issue. According to MVT troubleshooting:
Checking a PX20 ignition coil with an ohmmeter: 1 / measure between the mass (the coil fixing) and the input (terminal plug) = approximately 1.5 / 1.6 Ohms 2 / measure between the Mass (the coil fixing) and the outlet of the spark plug wire = approximately 6.08 Kilo-Ohms (kOhm) 3 / measure at the input (terminal) and the output (spark plug wire) = approximately 6.08 Kilo-Ohms (kOhm).
Control of a STATOR Premium or DD with internal rotor with an ohmmeter: Measure between the Red / Black wire and the Yellow / Green wire = 150 Ohms at +/- 10%
But that takes me back to my issue of no voltage output? What could cause a stator to not produce electricity??
Post by aragorn on Jun 16, 2023 11:42:53 GMT -5
By not getting power you mean not getting spark?
Post by awines2326 on Jun 16, 2023 11:47:54 GMT -5
