Post by RyanWiltshire on Jun 19, 2023 3:44:45 GMT -5
If you look at my YouTube short I made, it shows how my carb can’t sit flush, can anyone recommend or link me a spacer that will allow it or angle or extend past the nuts? Would be appreciated. The intake manifold is a Stage6 R/T intake manifold and the carb is a 21mm stage6 pwk r/t, if you need any dimensions of other let me know youtube.com/shorts/nZjxZaTbH_E?feature=share
Post by aeroxbud on Jun 19, 2023 14:00:50 GMT -5
What is stopping you from just twisting it round so it's vertical?
Post by RyanWiltshire on Jun 19, 2023 14:11:15 GMT -5
What is stopping you from just twisting it round so it's vertical? subframe nut, if you look in the video I do mention the subframe stops it.
Post by aeroxbud on Jun 19, 2023 15:57:34 GMT -5
You didn't actually mention that in the video. 🙊 you mentioned about it being a different frame. Can you post a couple of pictures up? It's not very clear in the video. I have seen worse angle carbs been run on bikes before.
