Post by cryslr on Jun 19, 2023 21:03:20 GMT -5
Post by Zino on Jun 20, 2023 0:47:16 GMT -5
looks great if you brush it with mop and glo it will bake a coating on that will help it keep from rusting . Just wipe it on every time you ride
Yasuni R
Jun 20, 2023 15:00:37 GMT -5
via mobile
Zino likes this
Post by cryslr on Jun 20, 2023 15:00:37 GMT -5
Thanks for the tip, went and got some. Runs good, went up to 95 jet from 92, went down to 6 gram rollers from 7. Keep my yellow contra and yellow clutch springs. Was able to do some long WOT runs, 312 temp GPS says 57 mph, but I don’t know how accurate it is out here in the country. Seems to have better top end, maybe a little slower off line, but don’t mind that so much as it’s easier to keep front wheel on the ground.
Post by aeroxbud on Jun 20, 2023 16:12:25 GMT -5
They are a great pipe I've had a couple. Try some slightly stiffer clutch springs. It might improve the take off.
Funny enough I was removing the restrictions from my stage 6 pipe today. It's the street pipe. And so easy to remove compared to the Yasuni Z or R.
