Post by loki007420 on Jun 20, 2023 17:12:58 GMT -5
I'm currently finishing up a 56mm stroker LC motor..
so im curious as to jets people are using, im running a 30mm Polini CP carb.
what weights are you running in your cvt?
im just looking for some starting points when i go to tune this weekend.. thanks in advance
Post by oldgeek on Jun 20, 2023 17:19:18 GMT -5
I know nothing of the larger bore motors such as yours. It would be very nice if you could share some pictures/information of your build.
Post by loki007420 on Jun 20, 2023 17:28:19 GMT -5
Here's a couple pics. I didn't take many pics, been kinda sitting on this for about 3 years now. Just finally starting to put it together
Post by oldgeek on Jun 20, 2023 17:54:32 GMT -5
The pictures are much appreciated. Is that cylinder the Tadia 56mm and does it use the 52.6 stroke crank? If so then you have almost 130cc of goodness there You putting it in a Elite? I have some experience stuffing a 52.6 stroke crank into a set of Kymco ZX cases that are similar to the AF16.
Post by loki007420 on Jun 20, 2023 18:02:23 GMT -5
The pictures are much appreciated. Is that cylinder the Tadia 56mm and does it use the 52.6 stroke crank? yes and yes
