Post by 1towman on Jun 27, 2023 11:16:34 GMT -5
So I picked up a 2005 Vino that has a 70cc kit on it and a 2004 Zuma and I was wondering if I could just swap motors and if not could I at least swap the kit? Yes I'm a newbie to the scooter world. thanx, ben
Post by moofus02 on Jul 7, 2023 23:31:28 GMT -5
The vino is short case with trenched cases from factory. The zuma is long case. That said you can swap to ends no problem. Both should have 10mm pins unless someone swapped cranks in the vino. If so you could steal that also
Post by Zino on Jul 8, 2023 9:19:17 GMT -5
you can swap the kits but why not just put a fresh kit on the zuma .
It would be more work to swap on and off cylinders on 2 scoots then 1 scoot added bonus you have a good sccot for a friend to ride with you
