Post by stan on Jun 29, 2023 11:18:04 GMT -5
Hi guys! Im new ,so i have a question about the stage6 manifold with a 21pwk carb . I've been wondering why there are 2 brass fitting/2 nipple(or however it is called) on the manifold i believe its for the manual petcock vacuum but there's two of it and my carb also has one for the vacuum line so idk why there are so many. Im thinking: petock to manifold and close one nipple and close the one on te carb or close both on the manifold run it petcock to carb or petcock to manifold and the other nipple left on the manifold to the carb. Im very confuse ,help!.
Post by RyanWiltshire on Jun 29, 2023 13:58:21 GMT -5
Hi guys! Im new ,so i have a question about the stage6 manifold with a 21pwk carb . I've been wondering why there are 2 brass fitting/2 nipple(or however it is called) on the manifold i believe its for the manual petcock vacuum but there's two of it and my carb also has one for the vacuum line so idk why there are so many. Im thinking: petock to manifold and close one nipple and close the one on te carb or close both on the manifold run it petcock to carb or petcock to manifold and the other nipple left on the manifold to the carb. Im very confuse ,help!. I think that is the same one on my old Aerox, it's a vacuum and Oil line I believe if you want to use the oil bottle instead of premix? I can't see it being anything other than vac and oil. the biggest nipple (haha) is the vac line, keep the rest plugged off mate if your premixing
