Post by anaweir on Aug 7, 2023 21:13:12 GMT -5
So the stock exhaust on my RH 50 grenaded itself and shredded the baffle,so it basically a tin can. I replaced with a Yasuni exhaust. Does the tube with the filter that leads from the exhaust really matter?
Post by aeroxbud on Aug 8, 2023 4:07:41 GMT -5
Are you on about the baffle? The exhaust is designed to be a certain length. And have an amount of pressure. This helps the pipe work correctly. A two stroke pipe is also designed to help pull the fuel through for the next charge. By removing a piece. You will be undoing all of the work Yasuni put into the pipe. It would run without it. But then you might as well run a cheap pipe from ebay.
Post by Zino on Aug 8, 2023 7:40:54 GMT -5
That tube with a filter that connect to the exhaust on one end and tothe cvt on the other is only for the stock exhaust to reduce emmissions ,. So delete it
Post by anaweir on Aug 8, 2023 14:28:53 GMT -5
Are you on about the baffle? The exhaust is designed to be a certain length. And have an amount of pressure. This helps the pipe work correctly. A two stroke pipe is also designed to help pull the fuel through for the next charge. By removing a piece. You will be undoing all of the work Yasuni put into the pipe. It would run without it. But then you might as well run a cheap pipe from ebay. I replace the stock exhaust with a yasuni since the stock one failed, just wanted to make sure i wouldnt hurt anything by removing that filter and tube
Post by aeroxbud on Aug 8, 2023 14:43:07 GMT -5
Are you on about the engine side of the exhaust? Or the other end? Not quite sure what you mean by filter.
Post by Lucass2T on Aug 9, 2023 0:44:53 GMT -5
Are you on about the engine side of the exhaust? Or the other end? Not quite sure what you mean by filter. He means the 'second air' system or whatever its called. Delete everything that connects the air filter with the exhaust. Cap off the hole in the airbox.
