Post by smakudre on Aug 13, 2023 15:53:17 GMT -5
I have a question regarding whether it's worth it and what the potential benefits and downsides would be. I'm tempted for upgrading to a 19mm carburetor on my stock Derbi moped. Is this upgrade worthwhile, or should I remain with the 17.5mm carburetor? (I have the 19mm, i would not buy it)
Post by oldgeek on Aug 13, 2023 17:00:15 GMT -5
Try it and see, it would be a great learning experience for you in carb tuning. If it does not work out to your satisfaction you can go straight back to your original setup as long as you do not modify anything to make the 19mm carb work. The short answer is no, as long as your stock carb is not restricted and is tuned good you will not notice much of a difference IMO. Which Derbi do you have? Some are restricted from the factory.
Post by smakudre on Aug 13, 2023 17:44:13 GMT -5
I have a 2009 Derbi Senda SM , all of the restrictors are removed
Post by aeroxbud on Aug 13, 2023 18:07:09 GMT -5
Post by Lucass2T on Aug 14, 2023 0:19:55 GMT -5
I have a question regarding whether it's worth it and what the potential benefits and downsides would be. I'm tempted for upgrading to a 19mm carburetor on my stock Derbi moped. Is this upgrade worthwhile, or should I remain with the 17.5mm carburetor? (I have the 19mm, i would not buy it) Try it. I think on the long run you're gonna like the 17.5 more. In the other hand the HM cre50 comes with a 19mm stock. But I think they also come with a expansion chamber exhaust.
gi
Scoot Junior
My motto is 'Runner & Roll'
Post by gi on Aug 16, 2023 6:46:35 GMT -5
You got a spare carb already, why not? Worst case scenario you can go back to the 17.5, but I doubt , especially if the 19mm carb is a Dell'orto phbg or Polini cp.
Post by smakudre on Sept 6, 2023 13:47:33 GMT -5
I have had the 19mm carburetor on my Derbi for a few weeks now. I'm not complaining because it definitely makes it go faster (the top speed hasn't changed), but it has improved the acceleration. If you configure the carburetor properly, it can enhance the performance even on a 50cc. Occasionally, it tends to choke when I'm in first gear and give it full throttle, but I've gotten used to it.
Post by classacted on Sept 6, 2023 16:01:51 GMT -5
thanks for the info
