Post by dylanrayymr on Aug 19, 2023 11:24:27 GMT -5
So I have a 2007 Eton beamer iii, I want to know if I can swap a 3j00 49cm3 minearelli motor on it from a malaguti f10...? I can post pictures of the Eton and malaguti scooters. I have questions as well about stuff on etons. I'll type more if I get some replys
Post by 190mech on Aug 19, 2023 16:18:57 GMT -5
It should fit if the donor engine is a long case..
Post by dylanrayymr on Aug 19, 2023 19:15:52 GMT -5
It should fit if the donor engine is a long case.. Ok, And I also needed to know a good place for parts for the beamer 3's motor Incase I choose not to swap motors
Post by 190mech on Aug 20, 2023 3:47:14 GMT -5
Post by dylanrayymr on Sept 3, 2023 1:49:27 GMT -5
Hey so turns out the cylinder piston basically whole top end of the F10 malaguti is in excellent condition and will totally work on this Eton. BUT my rear tire just so happened to pop yesterday. Stock tires are 130/10 pretty fat not the usual.. I have a 3.50-10 tire on the rim off another parts scooter. Can I use it as a donut persay until I get the 130
Post by dylanrayymr on Sept 3, 2023 1:50:10 GMT -5
Post by 190mech on Sept 3, 2023 4:12:02 GMT -5
Yes, I ran my Beamer like that for a while during an engine swap, it did fine, just looked funny!
Post by dylanrayymr on Sept 4, 2023 1:21:25 GMT -5
So that tire will work?! It's so much smaller but it's a 10.
Post by dylanrayymr on Sept 4, 2023 1:21:36 GMT -5
Yes, I ran my Beamer like that for a while during an engine swap, it did fine, just looked funny! ?
Post by 190mech on Sept 4, 2023 4:04:44 GMT -5
Not on the Beamer wheel,the whole assembly(wheel and tire) is what I;m saying..
Post by Lucass2T on Sept 4, 2023 5:15:59 GMT -5
Malaguti F10 has a short case motor, exactly the same as on my Yamaha Axis. Aprilia Sonic also has a short case motor. Not sure about max tire size, 3.50 might the max.
Post by dylanrayymr on Sept 4, 2023 11:27:33 GMT -5
Not on the Beamer wheel,the whole assembly(wheel and tire) is what I;m saying.. so I'm saying etons are equiped with 130/90-10 factory rear wheel size. I have a 3.50-10 tire off a keeway scooter. It's on the rim and ready to be aired and potentially put on as a temporary fix will it work
Post by 190mech on Sept 4, 2023 14:17:15 GMT -5
I think so!Try it!!
Post by dylanrayymr on Sept 4, 2023 14:17:38 GMT -5
Yes, I ran my Beamer like that for a while during an engine swap, it did fine, just looked funny! I ended up plugging the tire with a repair kit and it holds. How do I post pictures I'm trying to find out information and learn about scooters specifically 2t tuneing etc I know the basics and stuff. More than a person who hasn't owned or drove scooters would.
