Post by RyanWiltshire on Sept 8, 2023 2:16:45 GMT -5
I have been trying all sorts of adjustments. I recently put a new pipe on my build (yasuni c16, I previously had the stage6 mk1 pro rep, sports exhaust) not sure what is causing the low down bog, best way to describe it. you go to pull the throttle and there is just dead movement, boggggggggg, then it just shoots off like a rocket. I know it's CVT, but I have lost ideas on what to change, I have done rollers, adjusted clutch, done shimming. it's a MK2 Racing, Dellorto 21mm, Stage6 MK2 Clutch, Stage6 Overrange kit, everything else is stage6, but that is the main parts, whole CVT is S6 rollers 4.5gs all around, pink contra spring I do have the orange contra and a load of other weights that I can try, if you feel like you could suggest some stuff for me to try I would appreciate it
Post by 190mech on Sept 8, 2023 4:09:08 GMT -5
You need stiffer clutch springs..
Post by RyanWiltshire on Sept 8, 2023 4:29:49 GMT -5
You need stiffer clutch springs.. stiffest ones you can get, red ones from stage6
Post by Zino on Sept 8, 2023 16:05:17 GMT -5
Post by Zino on Sept 8, 2023 16:20:48 GMT -5
Post by RyanWiltshire on Sept 9, 2023 3:14:22 GMT -5
Thanks a lot mate. I think I’m going to spend some time and do some trial & error with clutch adjusting and shimming along with trying out a wider range of mixed rollers this time and spend a good day seeing what I can get out of it.
