Post by alexzuma on Sept 24, 2023 19:58:40 GMT -5
I was wondering if anyone knew what part this is on the Yamaha Zuma 50cc, its a 2009 and its been leaking from this but im not sure if its the air box and if it can be replaced or just deleted, if anyone knows please let me know!
Post by Zino on Sept 25, 2023 7:44:43 GMT -5
that comes off the exhaust pipe and goes to the air box it is designed to help pull fresh air into the exhaust pipes catalytic converter . It does not add performance . When you upgrade to a performance pipe none of them need this pollution control filter .
When you delete it remember to plug the hole that goes to the actual airbox so you are not pulling extra air into the air box making you run lean.
Post by alexzuma on Sept 25, 2023 18:09:57 GMT -5
that comes off the exhaust pipe and goes to the air box it is designed to help pull fresh air into the exhaust pipes catalytic converter . It does not add performance . When you upgrade to a performance pipe none of them need this pollution control filter . When you delete it remember to plug the hole that goes to the actual airbox so you are not pulling extra air into the air box making you run lean. Thank you, what could i use or what should i use to plug it? is there anything in specific i should use or does anything work?
Post by Zino on Sept 26, 2023 7:05:02 GMT -5
Duct tape works
