Post by leon49 on Sept 28, 2023 4:10:26 GMT -5
Do i have to split block on gilera runner 99 thanks for replies
Post by aeroxbud on Sept 28, 2023 4:38:02 GMT -5
What are you trying to do? Replace the seals?
Post by leon49 on Sept 28, 2023 15:59:14 GMT -5
Tryna change whole pump bearings,seal brand new set from box
Post by aeroxbud on Sept 29, 2023 4:24:52 GMT -5
I think to change the whole pump you might need to split the case's. Not 100 percent sure though. If your impeller is okay you can replace the rest of it without splitting the cases I think.
Post by leon49 on Oct 3, 2023 6:35:07 GMT -5
Thanks but i thnnk impeler is still good ima try to change berings and seals
