Post by markyb on Oct 22, 2023 8:04:15 GMT -5
Hi please can someone help me figure out where all the fuel pipes go on my 2 stroke benelli 49x quattronove. The last owner disconnected them and I can't figure it out. I have a breather from the engine also which pipes connect to the small plastic reservoir and what pipes connect to the fuel pump? Any help would be greatly appreciated many thanks
Post by aeroxbud on Oct 22, 2023 14:39:28 GMT -5
If you look on the bar on the left side of the screen. The one at the top is for manuals. Most 139QMB are very similar. So you should find something to help.
Post by markyb on Oct 22, 2023 15:22:26 GMT -5
I have checked multiple manuals but with no joy il keep trying. Thank you for your help
Post by Zino on Oct 22, 2023 16:27:43 GMT -5
take a picture so we can see what you see
Post by markyb on Oct 24, 2023 12:31:23 GMT -5
Post by 90GTVert on Oct 27, 2023 5:08:19 GMT -5
Post by markyb on Nov 2, 2023 9:06:47 GMT -5
Thank you. My fuel tank goes to the little white plastic pot and then from the pot to the carb. Not sure if that's correct but it works. Any idea how to wire a 5 wire start stop switch to a 4 wire loom please? I have put a post in general chat with a picture of the switch I have. I will have a picture of the loom side wires when this storm passes. Thank you I appreciate you
