Post by dwint on Oct 23, 2023 16:08:44 GMT -5
I just put in a new malossi piston and rings (with oil)and only reads 120 pounds.Is that good for malossi sport?This is my third set and never checked before.Just curious.It will improve after the rings seat in?Never started engine yet and throttle slide is removed.
Post by dwint on Nov 6, 2023 9:18:38 GMT -5
I just put in a new malossi piston and rings (with oil)and only reads 120 pounds.Is that good for malossi sport?This is my third set and never checked before.Just curious.It will improve after the rings seat in?Never started engine yet and throttle slide is removed.i just found out i have a bad seal behind stator.Problem found.
