Post by etonbeamerinfoplease on Oct 31, 2023 0:24:42 GMT -5
I have a 2005 Eton beamer 2. And I want to put 15/42 gears in it. But I'm not sure what model scooter to order for. Any help is appreciated. I know that's long gearing but I have 70cc bbk on it already. The big bore kit was for a 02-11 ZUMA but I've heard the transmission is different. Anyone changed the gears in a 2005 Eton beamer 2 model pn2b?
Post by 90GTVert on Oct 31, 2023 6:14:04 GMT -5
Post by etonbeamerinfoplease on Oct 31, 2023 6:58:56 GMT -5
Any ideas on a cheap CDI that's adjustable?
Post by 90GTVert on Oct 31, 2023 7:07:11 GMT -5
There’s stuff on aliexpress that’s fully programmable but it’s not plug and play.
Post by etonbeamerinfoplease on Oct 31, 2023 7:12:39 GMT -5
There’s stuff on aliexpress that’s fully programmable but it’s not plug and play. . Ok do you know of any YouTube videos that will help me change the gears? Any links are appreciated.
Post by Zino on Oct 31, 2023 16:09:03 GMT -5
The cdi you have in the eton can be modified so it revs all the way out . there is a way to derestrict the stock cdi Cutting that green wire on the back of the beamer cdi does let it rev past 8000 rpms .
It is in the beamer service manual supplements So the info is provided by the manufacturer
Here is the service manual link get2itparts.com/etontech/SM_PN2.pdf
Page 61 references the cdi fix
Post by etonbeamerinfoplease on Oct 31, 2023 19:22:51 GMT -5
Post by etonbeamerinfoplease on Oct 31, 2023 19:36:38 GMT -5
The cdi you have in the eton can be modified so it revs all the way out . there is a way to derestrict the stock cdi Cutting that green wire on the back of the beamer cdi does let it rev past 8000 rpms . It is in the beamer service manual supplements So the info is provided by the manufacturer Here is the service manual link get2itparts.com/etontech/SM_PN2.pdf Page 61 references the cdi fix
Post by etonbeamerinfoplease on Oct 31, 2023 19:39:01 GMT -5
Post by etonbeamerinfoplease on Oct 31, 2023 19:44:05 GMT -5
My CDI only has 2 pins I believe that means no REV limiter. And honestly if it has the rev limiter and I'm already doing 53mph with just 70cc bbk and dlh high speed variator I'm good with rev limiter. Stock carb,exhaust,airbox(drilled like 5 3/8th holes in the air box and was running a .90 main jet to be safe. I was WOT non stop before 70cc kit.
I have all the original paper work from dealership if anyone needs info or diagram they can't find online.
