vacationer
On Vacation
Post by vacationer on Nov 19, 2023 15:10:13 GMT -5
So ever since I bought my Zuma (88-01), it’s been pretty loud. I was told this was because the CVT cover was cut, which makes sense to me. But recently, after I removed and painted my exhaust and repacked the silencer, it’s gotten gradually louder. This week, I noticed the exhaust was attached by almost nothing and fixing to just fall out. Apparently one of the bolts holding it the cylinder had snapped as a result of the fact that the large bolt on the top side of the exhaust on the outside had disappeared at some point.
Yesterday, I put some new bolts on and replaced the former paper gasket with a plastic one about half a cm thick that had a rubber o-ring seated inside a groove on one side. I put some high temp gasket maker on as well since the gasket wasn’t a perfect fit. Today, when I started up the engine, it was quieter than I’d ever heard it, but after about a minute of riding, part of the new gasket broke and flew off.
What did I do wrong?
Post by aeroxbud on Nov 19, 2023 15:32:30 GMT -5
Post by oldgeek on Nov 19, 2023 15:42:32 GMT -5
Sounds like you used a carb intake isolator instead of an exhaust gasket. Plastic will not take the heat the exhaust produces.
vacationer
On Vacation
Post by vacationer on Nov 19, 2023 16:47:11 GMT -5
oldgeek Okay that’s definitely what happened. I guess I just saw the shape of it and assumed. I found in my stuff a used gasket like the one in the first link you posted, aeroxbud. Think I can use it again? I’d use the paper one but I think the reason the exhaust was coming off before was that, with a paper gasket, the pipe doesn’t align both with the bottom bolts and with the one on the outside - at least not at the same time.
Post by oldgeek on Nov 19, 2023 17:40:43 GMT -5
vacationer
On Vacation
Post by vacationer on Nov 21, 2023 9:34:03 GMT -5
Okay duh. Not sure why I thought a paper gasket would last. I ended up reusing the ring gasket and it’s worked like a charm so far. I was worried it wouldn’t be wide enough, and it still might not be so I’ll have to keep an eye on things.
