kevino
https://www.youtube.com/watch?v=04dSGwAssRA
Post by kevino on Nov 28, 2023 13:45:07 GMT -5
kevino
Post by kevino on Nov 28, 2023 14:03:02 GMT -5
Sorry the camera has a mind of its own. I spent months putting in a BBK. Turning winter here and my wife wants out of the garage. So I moved into a shed. It idles okay but sort of "Chokes" when accelerating. I wonder if it's timing? I've had it a couple years and never had it serviced.
kevino
Post by kevino on Nov 28, 2023 14:09:30 GMT -5
kevino
Post by kevino on Nov 28, 2023 14:10:04 GMT -5
I give up
Post by GrumpyUnk on Nov 28, 2023 15:40:17 GMT -5
Dunno what you are trying to take a picture of.. Timing is pretty well fixed by design. You can adjust by ovaling mounting holes to move the 'trigger' pickup. The other components are non-adjustable. If you have good spark, it should be in time. If you 'stutter' or bog or ?? when you open the throttle, check the accelerator pump on the carb, and its linkage. The flat metal may have gotten tired of pusning and may not be operating the pump when the throttle is first opened, which is when it is needed most. tom
kevino
Post by kevino on Nov 29, 2023 12:55:23 GMT -5
Dunno what you are trying to take a picture of.. Timing is pretty well fixed by design. You can adjust by ovaling mounting holes to move the 'trigger' pickup. The other components are non-adjustable. If you have good spark, it should be in time. If you 'stutter' or bog or ?? when you open the throttle, check the accelerator pump on the carb, and its linkage. The flat metal may have gotten tired of pusning and may not be operating the pump when the throttle is first opened, which is when it is needed most. tom Thanks, I had to replace the throttle cable and there's slack that I haven't tightened yet.
kevino
Post by kevino on Nov 29, 2023 14:09:03 GMT -5
kevino
Post by kevino on Nov 29, 2023 14:12:12 GMT -5
Trying to show that I moved it do a shed where it shares space with a treadmill and an old rug etc.
