Post by tgbshibox on Dec 3, 2023 10:34:14 GMT -5
Recently i have been having a problem with my tgb bullet 50rr. Whenever the scooter feels like it, using the blinkers, brakes or horn cuts my ignition and speedometer.
The electrical things i have done to it is connect the ignition to the hazard light button om the dash, of cource disconnecting the plug so it doesnt constantly blink, and connect a "police button" rpm limiter to the cdi so that i dont get caught by taking the variator ring out. I also managed to cut the cable i connected the rpm limiter to leading the ignition to let be turnt on, but the engine would not dtart. I simply soldered the cable back and that did wonders.
The battery is checked to be good, and i tried with my battery from my motorcycle wich did not fix the problem. Would really like to fix this as its akward having to start the motor again whenever i forget about it in a junction😅 Ill update if the elstart also turns the ignition of, planing to make it start without brakes beeing pressed, just waiting for a new one to arrive in the mail
