Post by jbird89 on Dec 3, 2023 19:05:16 GMT -5
I have a rectangle shaped hole right by the gear oil drain and can smell burnt gear oil, sometimes it boggs down and almost stalls, I just keep refilling until I can get the money to fix it, I am not much of a mechanic but if I can get the right part and gaskets and screws I can figure it out. I think it is the crankcase. Can someone help me with possible part info 2016 Adly Rt50 motorcycle
Post by 90GTVert on Dec 3, 2023 23:36:00 GMT -5
That may just be the gearbox overflow. If it overflows and you keep adding more, it will just keep overflowing. That said, if you think you have a real leak, drain the gear oil and measure it to be sure if you have enough. If you use a clean container you can pour it back in. This may not be related to the bogging and stalling. www.adlyparts.com/schematics/scooter-parts
Post by jbird89 on Dec 22, 2023 14:52:13 GMT -5
Ok thanks I did drain and put new fluid in it is the sae90 now there is white smoke coming out of exhaust also I think the back wheel has a barring messed up, how do I go about fixing that, I think it's causing metal fragments in my gear oil, would I need a whole new gearbox case and what else would I need.
