Post by morphex on Dec 28, 2023 7:26:53 GMT -5
Hi. I have this air filter: photos.app.goo.gl/iUpL8ZoHMeaJzoot7And instead of repairing it or replacing it, I was thinking of using a "racing air filter" which is a short little stubby thing. It's a lot cheaper. What do you guys think about that? It will be mostly covered by the scooter panels. Mostly. Is it possible to look up the diameter without opening up the scooter?
Post by aeroxbud on Dec 28, 2023 9:44:20 GMT -5
I wouldn't put a pod filter on it. You would need to change the jetting in the carb. They make the bike much more noisy, and suck in water.
Post by morphex on Dec 28, 2023 10:32:30 GMT -5
I wouldn't put a pod filter on it. You would need to change the jetting in the carb. They make the bike much more noisy, and suck in water. Yeah, I suspected it could suck in water. OK, stock it is then, or something that makes use of the existing prefilter (?) that's up under the plastic in the rear.
