Post by Misfit J on Dec 31, 2023 14:15:48 GMT -5
Hi all. This is my 2021 mvp 139qmb build. Iv spent a lot of time digging through the years of info on this forum. Tips,tricks, what worked what didn't and it's all lead me too Ssp-g.
50mm Uni air filter 21mm Oko D slide, also have a 19mm oko Gy6 intake Naraku wedge spacer 50mm Ssp-g 23/20 head Ssp-g cam 50mm Airsal piston and jug Stock crank amazon exhaust
Ncy ignition system- cdi, coil , wire and cap Ngk spark plug All emissions, vac lines and fuel pump are deleted. Gravity feed fuel line setup.
89mm Ssp-g variator and drive face Dr. Pulley 6.5g sliders Gates belt Ncy bell, clutch and torque sheave 1,000 rpm clutch and contra springs 17/49 secondary gears Pulls great and hits 52mph at 8500/8800 rpm. Still working on getting the 21 better dialed in or swap to the 19 oko also getting a 20mm round slide to try and see if that works better.
The bike has been lowered 1 1/4"- cut the stops out of the tree/ shorter shock in the back. Ncy flat track handle bar. Sss Yamaha srt8 clamp. Converted head lights from ac to DC to a switch. All led lights, 2 wire led relay. Temp/tach gauge, gps speedo. I cut the inside of the plastic side fairing vents, left the center section and installed chrome mesh turned out great.
scooterarmy
Scoot Junior
www.scooterarmymostlyofficial.com
Post by scooterarmy on Jan 1, 2024 18:24:55 GMT -5
There's no pictures? Show us this beast.
