ghost
Scoot Junior
Post by ghost on Feb 5, 2024 14:45:07 GMT -5
I have a Aerox and i need some recommendation for what clutch and variator kit should i get for wheelies? The setup right now is : Stage 6 streetrace 70cc + 21mm Polini carburetor + Malossi air filter + exhaust Yasuni R pipe and stock CVT.
Post by Zino on Feb 6, 2024 20:30:15 GMT -5
malossi polini and stage 6 all make great products
Variator I have used both polini and malossi I would call them even
I have used the malossi delta clutch,malossi sport clutch and polini sport
The Malossi delta was way over kill for a sport build it just has too many combos to dial it in and you have to disasemble the whole clutch to swap springs and weights and set tensions. This is where I feel stage 6 racing clutch and Polini racing is better you dont have to take the whole clutch apart to change tension on the springs
for a sport level build Where you just change springs Malossi Polini clutches are equal to me .
