Post by mafchew on Feb 8, 2024 11:09:35 GMT -5
Hi all My lad has had starting & running issues with his Echo 50 21 plate Cuts out occasionally when shutting throttle down,poor starting on now not starting! Engine turns over and tries to run really good spark no blockers in fuel tank & correct fuel in tank! I have removed carb to clean out the bike is standard no mods! Any ideas please??
Post by geoffh on Feb 8, 2024 15:01:18 GMT -5
Hi and welcome,is it a 2 stroke or four?? The 2ts can be "fussy". Use the directory icon left on this page to get to the sites technical section (no start section) for self help,but keep on asking if you can,t sort it.
Post by aeroxbud on Feb 8, 2024 15:54:36 GMT -5
I would give the valves a check. Even with low miles, they can be out of adjustment.
