Post by rjwittmann on Mar 6, 2024 19:33:40 GMT -5
My vento triton r4 has a crank with 12mm wrist pin. My question is are the crank bearings the same size for a 10mm and 12mm?
Post by oldgeek on Mar 6, 2024 19:37:27 GMT -5
If you are speaking of the 2 bearings, 1 on each side of the crank there is no difference. The small end bearing is what makes it a 10mm or 12mm
