Post by rjwittmann on Mar 6, 2024 20:02:30 GMT -5
So I got my new belt today. But it’s shorter than the old belt. I ordered 788-17-28. Should I have ordered a 788-17-30? Or did the old belt stretch that much? The old belt doesn’t have any marks on it so I kinda guessed when I ordered it. So it fits just the cvt isn’t working correctly now. I even tried adding shims.
Post by oldgeek on Mar 6, 2024 21:09:31 GMT -5
The Chinese belts are usually a headache waiting to strand you. Stick with Bando from a reputable source 788-17-28 788 is length, 17 is the width, 28 is the angle
EDIT: scratch that, I am not sure which belt your roughhouse uses. I am sure someone else will know. You could measure the length of your old one by making a mark on it, and roll it out on a flat surface then measure the distance between the marks
Post by Zino on Mar 6, 2024 21:25:28 GMT -5
What brand belt did you order The stock roughhouse belt is bando 738 x18x30
Belt size
Mar 6, 2024 21:47:01 GMT -5
via mobile
Post by rjwittmann on Mar 6, 2024 21:47:01 GMT -5
The Chinese belts are usually a headache waiting to strand you. Stick with Bando from a reputable source 788-17-28 788 is length, 17 is the width, 28 is the angle EDIT: scratch that, I am not sure which belt your roughhouse uses. I am sure someone else will know. You could measure the length of your old one by making a mark on it, and roll it out on a flat surface then measure the distance between the marks This is for a vento triton r4. Not a roughhouse.
Belt size
Mar 6, 2024 21:47:45 GMT -5
via mobile
Post by rjwittmann on Mar 6, 2024 21:47:45 GMT -5
What brand belt did you order The stock roughhouse belt is bando 738 x18x30 This is for a vento triton r4.
Post by Zino on Mar 7, 2024 7:46:39 GMT -5
