Post by karlsson144 on Mar 25, 2024 16:52:49 GMT -5
Greatings from sweden
I have a yamaha slider 2009 with ducati ignition system and the problem is that the cdi needs a battery to run. I have no idea on how to set up and wire the battery.
Should i just take the red wire from the voltage regulator and just grouns the battery to the frame or should i do it in some other way?
Timmer
Post by Timmer on Mar 26, 2024 15:27:39 GMT -5
Didn't the ignition system come with a wiring diagram? Or do you have more info on the system?
