Post by br4inl3ss on Apr 29, 2024 10:33:52 GMT -5
thanks.
thanks for all that info.
first, before i forget... where thoes this passage goes ? (smallest one, to the left)
the intake is stock 139qmb one. i quess the naraku is made the same way but QUALITY material and manufacturing.
damn this shit is hard to remove what the hell.... had to "vulcanize", red-hot the damn rubber... and it wasnt enought had to wirebrush it lmao.
i re-verified that all passages are free flowing, both air and liquid (gas, acetone, vinegar).
they're all perfect but i'm questioning one.
it seems to go ont to the small hole under the slide, but under the carb we see its form and it goes way further.
also its not a straight passage because even tho it comminucate with the said small hole its not aligned to it. the passage is a bit to the left side but the hole is right in the center.
look the passage form i'm talking about. again the smaller one, at the bottom of the bowl area in the picture.
i dont see why they would make such a long passage if it stop at the small hole under the slide. but what do i know.
anyhow, this one is difficult to test properly i cant plug everything at the same time.
so MAYBE this one is clogged ?
thats the small hole under the slide (haha ofcourse not the jet hole).
the hose.. ill try to find something cheap. low budget and i ordered a needle set + i gotta replace the handlebar plastic holding the headlight. the fix i did isnt holding up and the plastic is cheaper than buying the required stuff to do a proper job lol.
i did check the fuel mix screw. it SEEMS in good shape.
UPDATE
i tested with the custom temp intake. no change. it wasnt an intake leak at all.
tested with a propane torch and see. no change at all. its blowing full speed. had to stop it was smelling propane in the whole garage.
also had to put back 32 idle jet its literally the only way for it to idle. its 1.5 or 2 turn out from fully seated. so this size is fine.
starting to thing i really need to mod my slide (i hsve 30 and it seems to be the smallest available) adding material so its a richer slide.
