Post by guszec on Apr 20, 2024 10:59:27 GMT -5
Hello all of You, I'm new here. I have a generic 12 inch 139qmb scoot (Motom Gipsy, Moto- Magnus Capro style). I've mounted this config on it:
Naraku 52.4mm kit
Malossi Multivar variator
Naraku variator counterplate
Naraku torque driver
Naraku clutch bell
Naraku Twist Control
Naraku crank
Top Racing adjustable friction
Naraku jet flow spacer
Generic chinese sport camshaft
Handmade exhaust pipe with 25mm diameter (exhaust original)
Pollini Airbox air filter
Red clutch springs
White central spring
6 or 7gr rollers, I don't remember correctly
The ignition coil and cdi remained original. The intake manifold is a chinese generic for 125/150 engines.
The problem is- i have two 24mm carbs for it. One is generic chinese, and one is Naraku. The scoot runs better on the chinese one, but I cannot find right adjustment spots. For Naraku it goes like this:
-The needle needs to be all way up. If I lower it the scoot loses power immediately.
-Main jet above 98 will cause it to loose ignition on high speeds (85kph)
-Main jet smaller than 94 will cause it to loose some top speed
-The mixture screw is REALLY sensitive. It came already like that. I can screw it all the way down and the scoot will not die. But going over 1/8th of a turn from full closed will already cause the engine to run poorly! So I have full carb regulation within a REALLY small range. The best result i can get is that it tops like at 95/100kph with fatique.
-Has no problem idling
For the generic chinese it goes like this:
-Needle like naraku (but it has 3 steps instead of 5. Behavior is the same)
-Main jet above 108 will cause it to loose ignition on high speeds (85kph)
-Main jet smaller than 92 will cause it to loose some power and speed
-The mixture screw is not that sensitive, but is rough to turn sometimes and does not seem to do much. Screwed all the way down does significantly reduce RPM, but it does not die. The best result I can get is up to 110kph sometimes even. The engine seems to make less fatique and vibrations.
-Has problem idling on cold
I live in like 400m altitude. I don't know what to do anymore. The one thing I must do is to alignment of the intake manifold as it is like 1mm off the centre. But this does not explain the strange behavior of carbs. I don't know what can I do anymore with them. Maybe I'll try to cut the central spring in the carb? Anyone has any idea that could help me?
I'd like to know if someone had similiar setup, and would give me an idea on jetting the thing? The main jet as well as the other one. And I would like to know the probable cause of engine still idling with the mixture screw all way in?
Also- an recommended RPM meter. I have none currently. Bought some crap from china, but threw it out. At stable idle it gave 700- 1900RPM with the engine running smoothly
Thank You, have a nice road ahead
Naraku 52.4mm kit
Naraku clutch bell
Naraku crank
Red clutch springs
