hoecake
Scoot Junior
Post by hoecake on May 10, 2024 16:02:19 GMT -5
So i got a Derbi Atlantis from 2011. Piaggio motor. Only problem is my shits been leaking hella, and im starting to get tired of it. What's needed to remove the oil injection system and switch to good old premix? And is there any downsides? I wanna run 3% instead of what the fuel pump shoves in. Thanks alot people
Post by aeroxbud on May 11, 2024 19:02:45 GMT -5
On the Piaggio motors if you want to make it easy for yourself. Just remove the oil pump drive belt for the pump if it's air cooled. I would drain The oil tank as well, but no need to remove it. Then just cap off the oil line where it enters the carb. The only downside is you have to carry oil with you. And measure it out every time you fill up.
